Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Thickened slab footings
6 REPLIES 6
3337 Views, 6 Replies
How do you create thickened slab footings?:
\_____/
I cannot seem to modify a wall footing type to have the 'beveled' sides.
Even if it turns out that I can get beveled sides, how would I add a 'wall'
footing without the wall? (Usually we provide these footings below
non-bearing walls, which we don't typically draw or show.)
IOW, I just need a footing inserted inside the slab on grade, kind of like a
thickened slab edge (and it's mirror) without the edge.
Any suggestions would be appreciated.
David Kozina
6 REPLIES 6
I actually ended up having to create a new family using a Concrete Beam
family. Edit the family to have the beveled sides and place it in the
project paying attention to where the top of the beam/thickened slab is
located.
Leannie
"Not only is life a bitch, but it is always having puppies."
- Adrienne Gusoff
"David Kozina" <"David Kozina"> wrote in message
news:6065506@discussion.autodesk.com...
\_____/
David Kozina
That makes more sense than what I was trying.
I will look into this. Thanks much for the reply!
David Kozina
"Zaras" wrote in message
news:6066454@discussion.autodesk.com...
located.
Leannie
- Adrienne Gusoff
\_____/
kevms
I was just wondering if you had any luck creating a thickened slab with the bevelled edges. I posted a similar topic and was just wondering if there was any progress, as well what is the possibility of getting the family you created. I am new to revit and I am having difficulty trying to create a new family.
any help would be appreciated.
kevin
Kevin
Using Revit Structure 2012, 2013, 2014
I think I am getting the hang of this revit stuff
jsr
in reply to: kevms
I am also having issues with thickened slabs with the bevel on both sides.
Has there been any success for anyone?  Has anyone been able to make the "concrete beam with beveled edges" idea work?
Thanks in advance!
ArthurMacLeod5818
How about making an inplace foundation family. Make a profile of the section with the top at the bottom of the slab. Create a sweep and trace the nonbearing wall locations.
kevms
in reply to: ArthurMacLeod5818
Yep, I did this about a week ago. I created a new wall type with a sweep and also for the different wall thicknesses i use. when you have a deadline it is amazing what you can figure out.
Thanks anyway
Kevin
Rail Community
