Now I know you can tag rebar in section views, but does anybody know how I might include the reinforcement information on plan? I think it should be possible, I mean the width and depth is taken from the same schedule that contains reinforcement details. I'm just having trouble accomplishing it. I've tried clicking a tag and editing the family, and from there editing the label and creating a new parameter, but then I get stuck playing with parameters and families.
Please let me know if you've done this before or have some idea of what I can do.
Absolutely, sorry for my post not being clear. Let's say I have the following schedule:
Once you tag a beam, Revit uses the schedule to draw beams accordingly, so it's accessing the second and third columns. You can even include the size on plan:
What I would like to do is create new structural framing tags that will access the columns beyond name and size, the reinforement, so that I can label beams in the following manner. Would anybody have an idea how to accomplish this?
Hi, xp1!
Yes, it's possible. You can add custom shared parameter for beam family ("Reinforcement type", for example). Then you will need to add your shared parameter to structural framing tag. But in this case, "Reinforcement type" value will be input manually.
Do you think you could give a more detailed solution? I'm not quite sure how to follow your suggestions
