Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Swept blends
3 REPLIES 3
322 Views, 3 Replies
Swept blends
I'm new to Revit and need to detail a reservoir with a 1 in 150 fall along the shortest side, can anyone advise me how to create a swept blend through a right angle for the retaining wall profile. It seems to work alright for a spline
3 REPLIES 3
CoreyDaun
Hello, and welcome to the Discussion Groups!
Can you post a file or image of what exactly you are working with?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
This is a corner I built as a family using sweep. the thing is, one leg needs to be level and the one at 90 degrees needs to fall at 1:150 over 100m to the next corner, where it returns to being level but some 665 mm lower than the top end
CoreyDaun
So the slope must begin at the joint of the 90° angle? I can't immediately come up with a good way to accomplish that...
