Revit Structure
Revit Structure
Distinguished Contributor
RocksterB
Message 1 of 6 (314 Views)
Subscription Revit Structure 2012 Vibration Analysis Add On
314 Views, 5 Replies
09-11-2012 02:02 PM
Which Subscription download contains the Floor Vibration Analysis addon for Revit Structure 2012? I've found the one for 2011, but no 2012.
Product Support
fernanda.firman
Message 2 of 6 (279 Views)
Re: Subscription Revit Structure 2012 Vibration Analysis Add On
09-20-2012 03:36 PM in reply to: RocksterB
If you have subscription you can download Revit Structural Extension for 2012.
After downloaded, Floor Vibration Analysis should appear under  Extensions> Analysis (see attachment)
http://blogs.rand.com/files/revitext_rst2012_featuresummary_20110601.pdf
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
RocksterB
Message 3 of 6 (276 Views)
09-20-2012 03:40 PM in reply to: RocksterB
Specifically, what is the name of the files? Thanks!
Product Support
fernanda.firman
Message 4 of 6 (273 Views)
09-20-2012 03:55 PM in reply to: fernanda.firman
The name is exactly like in the pdf file I sent you: Revit Extensions for Autodesk Revit Structure 2012.
The Floor Vibration is listed in the pdf document under the Appendix.
Revit Clinic
RocksterB
Message 5 of 6 (271 Views)
09-20-2012 03:56 PM in reply to: fernanda.firman
Okay, I'll have a look in the morning.
RocksterB
Message 6 of 6 (256 Views)
09-21-2012 12:16 PM in reply to: RocksterB
So I was right, I do have the correct extension installed on my PC, but the panel for the extension doesn't show doesn't show. See that attached image. Why might that be?
