Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Structural Stiffener not showing hidden
4 REPLIES 4
jamesk
1536 Views, 4 Replies
I'm trying to show a structural stiffener hidden behind a structural framing member. No matter what i try i cant get the hidden line to show up. see attachment. the stiffener is visable when it is not hidden so its not a detail level issue. any ideas?
Tags (1)
4 REPLIES 4
AJA14
in reply to: jamesk
Did you try using the Linework tool. Type LW or access it from the modify.
Hope this helps.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Joe.Charpentier
in reply to: AJA14
You can use the linework tool or the manual hidden lines tool.
Structural Connections, as a category, do not generate automatic hidden lines in a Structural discipline view.
Joe
jamesk
in reply to: AJA14
great, thanks. this pretty much does exactly what im wanting.
Merlijn
in reply to: jamesk
linework is terrible. You could change the family category to structural framing and set 'material for model behavior' to concrete.
Rail Community
