I'm trying to show a structural stiffener hidden behind a structural framing member. No matter what i try i cant get the hidden line to show up. see attachment. the stiffener is visable when it is not hidden so its not a detail level issue. any ideas?
Solved by Joe.Charpentier. Go to Solution.
You can use the linework tool or the manual hidden lines tool.
Structural Connections, as a category, do not generate automatic hidden lines in a Structural discipline view.
Joe
linework is terrible. You could change the family category to structural framing and set 'material for model behavior' to concrete.
