I have the following problem: I have a U type stair, but with an irregular landing. One of those landings that has 3 different heights on it. So in the end, I solved it by using a stair by sketch. I sketched the U-shaped boundaries, then the risers, problem solved.
Except, I'm trying to adjust the structural depth (the thickness of the concrete slab that forms the bottom of the stair). When I do a stair by component, no problem, I simply go into nosing profile and adjust the structural depth there. But on stairs by sketch, I can't find the structural depth anywhere on the properties. And I can't go into a profile edit mode (like with walls) so as to alter the sketch profile.
So, how do you adjust the structural depth when you're sketching stairs?
I got it to the depth I'm looking for by playing around with the stringer carriage height. When I set it to 200, my depth went to 200 which is what I needed.
Did I just happen on the correct solution, or is there a better way to handle this?
