Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Structural code checking - no code registered - where to download code from?
4 REPLIES 4
Priitl220
1423 Views, 4 Replies
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
4 REPLIES 4
awes
in reply to: Priitl220
Priitl220
in reply to: awes
I have downloaded the toolkit. How would I get this error without it?
Running the code checking gives me the error and tells me to download something additional. Where can I get that?
From toolkit help.
Usage
Before you use the structural code checking tools, check that the following requirements are met:
  1. You have structural analysis results inside the Revit® project.
    Tip: Click Analyze tab Structural Analysis panel Results Manager to check that the results are saved inside the Revit project. DONE
  2. You have registered at least one code checking application.
    Note: Code checking applications are add-ins that you can download on the Exchange app (http://apps.exchange.autodesk.com/RVT/Home/Index) website.
    HOW can i register?
    WHAT to download in addtion to this "Structural Analysis and Code Checking Toolkit 2014 "?
Please check http://forums.autodesk.com/t5/Autodesk-Revit-Structure/Structural-Code/m-p/3897841
Artur Kosakowski
