Revit Structure
Revit Structure
Valued Contributor
Priitl220
Message 1 of 5 (1,009 Views)
Structural code checking - no code registered - where to download code from?
1009 Views, 4 Replies
05-15-2013 09:37 PM
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Please check http://forums.autodesk.com/t5/Autodesk-Revit-Structure/Structural-Code/m-p/3897841
Distinguished Contributor
awes
Message 2 of 5 (1,001 Views)
Re: Structural code checking - no code registered - where to download code from?
05-15-2013 11:22 PM in reply to: Priitl220
Valued Contributor
Priitl220
Message 3 of 5 (995 Views)
05-15-2013 11:40 PM in reply to: awes
I have downloaded the toolkit. How would I get this error without it?
Running the code checking gives me the error and tells me to download something additional. Where can I get that?
From toolkit help.
Usage
Before you use the structural code checking tools, check that the following requirements are met:
  1. You have structural analysis results inside the Revit® project.
    Tip: Click Analyze tab Structural Analysis panel Results Manager to check that the results are saved inside the Revit project. DONE
  2. You have registered at least one code checking application.
    Note: Code checking applications are add-ins that you can download on the Exchange app (http://apps.exchange.autodesk.com/RVT/Home/Index) website.
    HOW can i register?
    WHAT to download in addtion to this "Structural Analysis and Code Checking Toolkit 2014 "?
Product Support
Artur.Kosakowski
Message 4 of 5 (944 Views)
05-28-2013 04:56 AM in reply to: Priitl220
Artur Kosakowski
Member
iliribraimi
Message 5 of 5 (890 Views)
06-10-2013 01:42 AM in reply to: Artur.Kosakowski
