Good morning. My problem is within RST 2013. When I create a beam system it will only place a system tag, not a framing tag. This problem is only in a specific model/project. When I create a new model, either it be OOTB template or our office template, all is ok. I have double checked my loaded tags, beam annotation settings, and visibility graphics settings. I am able to create a beam with the tag on placement option and there are no problems. The only problem I have is placing the "framing tag" on a structural beam system.
Has anyone been through this problem or is still having this problem with their model? Thank you in advance for your help and your opinions.
MACHINE SPEC:
OS: Microsoft Windows 7 Professional 64-bit
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Max Clock Speed: 3.90 GHz
Number of Processors: 1
Number of Logical Processors: 8
Total Physical Memory: 31.96 GB
BANK 3: 8.00 GB @ 1333 MHz
BANK 1: 8.00 GB @ 1333 MHz
BANK 2: 8.00 GB @ 1333 MHz
BANK 0: 8.00 GB @ 1333 MHz
Graphics Card: NVIDIA Quadro 4000
Graphics RAM: -2,048 MB
Driver version: 9.18.13.1135
Solved by ebrown3876. Go to Solution.
To all, I have figured out why this is happening. It is directly related to my work Datum Level settings. What I mean is that if I create a new level and do not select the Structural option under Identity Data in the Properties the beam system tagging will not work for the Framing option, it will only work for the System tagging option.
