Structural Area Reinforcement in Conc Wall: Hook @ Bottom - NO Hook @ Top?
doni49
Mentor Mentor
Message 1 of 23
doni49
I placed a Structural Area Reinforcement on my Conc wall. I need it to show a hook at the BOTTOM of the vertical bars but NOT the top. So far, I've only been able to enable BOTH hooks or disable BOTH hooks.
Is there some way to accomplish this?
TIA!
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Replies (22)
Message 2 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
This way:
Rafal Gaweda
Message 3 of 23
doni49
Thanks Rafal.  You clicked "Remove System" (at about 0:03).
Now that I've done that, I no longer have a Structural Area Reinforcement.  I wanted to use this so that if/when a wall is changed (adding, moving or removing an opening) the rebar would update.
So is there no way to remove the hooks without losing the connectivity with the wall?
Don Ireland
Message 4 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Exactly.
No other way.
Rafal Gaweda
Message 5 of 23
doni49
Ok thanks anyway.  That seems like it's either a bug or an oversight on the part of the developers.  What's the point of creating the Area if I have to delete it just to not show the hooks at one end?  Please submit it as such.
Don Ireland
Message 6 of 23
sureshchotrani
You can achive the same if you do seperate operation for each wall & footing.
That way it seems to be technically correct too.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 7 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Sure.
You can do it also on this web page:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794&_ga=1.264022988.1926435475.14454...
Rafal Gaweda
Message 8 of 23
apjones
This may be a dumb question, but what rebar shape are you using?  Have you tried shape 17A?
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Message 9 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Sorry for dumb question, but are you talking about Area Reinforcement without deleting System?
Rafal Gaweda
Message 10 of 23
doni49
As best I can tell, Structural Area Reinforcement doesn't include an option or "Rebar Shape".
I know I can choose different shapes when placing separate bars.  But thanks.
Don Ireland
Message 11 of 23
apjones
Area reinforcing? Why do this in a wall?  I just used standard rebar with max. spacing settings. If you must use area reinforcing for this, you're probably out of luck.  To my mind, area reinforcing is better used for slabs....
Pete
Message 12 of 23
doni49
As stated above, I wanted the rebar to automatically adjust as openings are added, removed, modified or moved.  I went down this rabbit hole when I had to move a wall opening and ended up with rebar sticking up through the opening.
Don Ireland
Message 13 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Area reinforcing?
Yes, we are talking about Area Reinforcement - see thread subject - whatever reason for doing that for walls is.
Rafal Gaweda
Message 14 of 23
apjones
O.k. I understand you point now. We would never detail the footing dowels as part of the actual wall reinforcing. These would be separate from the area reinf. as you are using it in this case. Feel free to disregard my comments.
Pete
Message 15 of 23
apjones
O.K.  One more comment.
Is this what you are looking for or do I still misunderstand your question?
Pete
Message 16 of 23
doni49
Was there supposed to be a picture or something there?  If not, what do you mean by "this"?
Don Ireland
Message 17 of 23
apjones
Supposed to be a video. Let me see if I can attach it...
Pete
Message 18 of 23
apjones
Video should be there now.
Pete
Message 19 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hats off 🙂
Rafal Gaweda
Message 20 of 23
doni49
Here's a 3d view of my project file so far -- I've turned everything off except for rebar.  I've highlighted the vertical rebar from one wall that has no openings.  The wall opposite from that one also has no openings.  The other two walls each have two overhead doors and a normal 36" door.
Your video shows how to draw rebar in ONE SECTION.  But then I need a section at each opening.  If I use the area, the rebar will avoid the openings automatically.
Don Ireland
