Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steelwork beam to beam connections
1 REPLY 1
jneal88
549 Views, 1 Reply
I've been using Revit for some time but never found a tool for steelwork beam to beam connections. I've looked online and cannot find any add-ons or extensions to solve this problem.
The Autodesk 'steel connections' extension only creates baseplates or beam to columns.
The only software I could find is SDS/2 which is very expensive.
Anybody else had this problem and come up with a solution?
Seems silly it's still a problem in Revit 2015.
Cheers
Joe
1 REPLY 1
Rafal.Gaweda
in reply to: jneal88
You can export model to Autodesk Advance Steel
http://www.autodesk.com/products/advance-steel/overview
and make detailing there
Rafal Gaweda
