I've been using Revit for some time but never found a tool for steelwork beam to beam connections. I've looked online and cannot find any add-ons or extensions to solve this problem.
The Autodesk 'steel connections' extension only creates baseplates or beam to columns.
The only software I could find is SDS/2 which is very expensive.
Anybody else had this problem and come up with a solution?
Seems silly it's still a problem in Revit 2015.
Cheers
Joe
Solved by Rafal.Gaweda. Go to Solution.
