Revit Structure
Active Member
LukeLansdell
Message 1 of 9 (1,839 Views)
Steel Profiles
1839 Views, 8 Replies
09-20-2011 12:03 AM
Hi All,
Does anyone know where I can locate the following families? 'I-Beam"-IPE180 and 'C-Section' 180x70?
Many thanks,
L
engr_mondo
Message 2 of 9 (1,836 Views)
Re: Steel Profiles
09-20-2011 02:22 AM in reply to: LukeLansdell
Check under European sections.
Mondo
Active Member
LukeLansdell
Message 3 of 9 (1,821 Views)
Re: Steel Profiles
09-21-2011 02:05 AM in reply to: engr_mondo
Thanks Mondo,
Do you know where I can find the European Sections, I only have US metric and US imperial in my family?
Luke
Active Member
LukeLansdell
Message 4 of 9 (1,815 Views)
Re: Steel Profiles
09-21-2011 05:48 AM in reply to: LukeLansdell
Ok found the European Sections (UK libary?) I am still having NO joy in finding these 2 profile types IPE180 & 180C70, anybody please help?! Is there a way to print off all the libary profiles in Revit?
Thanks Luke
Product Support
jad.dellel
Message 5 of 9 (1,811 Views)
Re: Steel Profiles
09-21-2011 06:33 AM in reply to: LukeLansdell
If you've Revit Structre 2012, you can use the extensions:
Extensions-> Tools-> Families Generator
Change the regional setting to France:
And you can load IPE180:
For the C-profile, you can load the sadef database, but I don't find the 180x70 one:
May be this can help you!
Jad DELLEL
Structural Engineering Support Autodesk, Inc.
Active Member
LukeLansdell
Message 6 of 9 (1,809 Views)
Re: Steel Profiles
09-21-2011 06:56 AM in reply to: jad.dellel
I have 2012 but do not have extension in my menu? Where can I find it. Thanks for your help
Luke
Product Support
jad.dellel
Message 7 of 9 (1,806 Views)
Re: Steel Profiles
09-21-2011 07:03 AM in reply to: LukeLansdell
Log-in to the Subscription Center (http://autodesk.com/subscriptionlogin)
And download the SUbscription advantage Pack.
Jad DELLEL
Valued Contributor
helsinki_dave
Message 8 of 9 (1,397 Views)
Re: Steel Profiles
11-22-2012 10:52 PM in reply to: jad.dellel
Dear All,  is the link you provided here still relevant for Revit 2013. I'll ask this as a new post too - but being new to revit structures from an architectural background - it does my head in trying to find the right profile within families.
For example, here's my list that I need....but what familiy do I find them in!
US Imperial Range
W
HSS
HSSROUND
MT
ST
WT
C
MC
US Metric Range
W
HSS
HSSROUND
MT
ST
WT
C
MC
Employee
Joe.Charpentier
Message 9 of 9 (1,334 Views)
Re: Steel Profiles
12-04-2012 12:20 PM in reply to: helsinki_dave
In r2012 and r2013, you get content by running the installer.
(Windows  Control Panel>Programs>Programs and Features)
Select your version of Revit, and select "Unisntall/Change".
In the installer dialog, click "Add or Remove Features".
It will bring you the the "Maintain Product>Add or Remove Content" dialog.
You want to add checks in the checkboxes next to "US Imperial" and "US Metric".
Once they are installed, navigate to the content location for the install.
the default location is:
C:\ProgramData\Autodesk\<RevitVersion>\Libraries\US Imperial  or
C:\ProgramData\Autodesk\<RevitVersion>\Libraries\US Metric
Then look under the "\Structural Framing\Steel" or "\Structural Columns\Steel" folders- all the families should be there. (The names are obvious)
Joe
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
