Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel Profiles
8 REPLIES 8
Message 1 of 9
LukeLansdell
7697 Views, 8 Replies
Steel Profiles
Hi All,
Does anyone know where I can locate the following families? 'I-Beam"-IPE180 and 'C-Section' 180x70?
Many thanks,
L
8 REPLIES 8
Message 2 of 9
engr_mondo
in reply to: LukeLansdell
Check under European sections.
Mondo
Message 3 of 9
LukeLansdell
in reply to: engr_mondo
Thanks Mondo,
Do you know where I can find the European Sections, I only have US metric and US imperial in my family?
Luke
Message 4 of 9
LukeLansdell
Ok found the European Sections (UK libary?) I am still having NO joy in finding these 2 profile types IPE180 & 180C70, anybody please help?! Is there a way to print off all the libary profiles in Revit?
Thanks Luke
Message 5 of 9
jad.dellel
If you've Revit Structre 2012, you can use the extensions:
Extensions-> Tools-> Families Generator
Change the regional setting to France:
And you can load IPE180:
For the C-profile, you can load the sadef database, but I don't find the 180x70 one:
May be this can help you!
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Message 6 of 9
LukeLansdell
in reply to: jad.dellel
I have 2012 but do not have extension in my menu? Where can I find it. Thanks for your help
Luke
Message 7 of 9
jad.dellel
Log-in to the Subscription Center (http://autodesk.com/subscriptionlogin)
And download the SUbscription advantage Pack.
Jad DELLEL
Message 8 of 9
helsinki_dave
Dear All,  is the link you provided here still relevant for Revit 2013. I'll ask this as a new post too - but being new to revit structures from an architectural background - it does my head in trying to find the right profile within families.
For example, here's my list that I need....but what familiy do I find them in!
US Imperial Range
W
HSS
HSSROUND
MT
ST
WT
C
MC
US Metric Range
W
HSS
HSSROUND
MT
ST
WT
C
MC
Message 9 of 9
In r2012 and r2013, you get content by running the installer.
(Windows  Control Panel>Programs>Programs and Features)
Select your version of Revit, and select "Unisntall/Change".
In the installer dialog, click "Add or Remove Features".
It will bring you the the "Maintain Product>Add or Remove Content" dialog.
You want to add checks in the checkboxes next to "US Imperial" and "US Metric".
Once they are installed, navigate to the content location for the install.
the default location is:
C:\ProgramData\Autodesk\<RevitVersion>\Libraries\US Imperial  or
C:\ProgramData\Autodesk\<RevitVersion>\Libraries\US Metric
Then look under the "\Structural Framing\Steel" or "\Structural Columns\Steel" folders- all the families should be there. (The names are obvious)
Joe
