Revit Structure
Active Member
brooklynboyd2206
Message 1 of 2 (206 Views)
Split Columns
206 Views, 1 Replies
05-10-2012 11:17 AM
I have a full height column but like to split it at the floor levels. Is there a way to split this column? I know if you copy the columns from the arch. model there is an option to split at each level.
Employee
Joe.Charpentier
Message 2 of 2 (196 Views)
Re: Split Columns
05-11-2012 07:38 AM in reply to: brooklynboyd2206
The split tool cannot be used on vertical columns.
A workaround, you can change the column from Horizontal to Vertical, using the "Column Style" parameter in the properties palette.
After that, you can use the split tool on the columns.
However, the columns that are created retain the original level constraints- that is, they have the same top and bottom level, with different offsets.
In the future, you would be better off modelling the columns as they will be build, or as close as you can determine that at the start of the project.
Joe
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
