Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
special text
3 REPLIES 3
seferj
462 Views, 3 Replies
special text
How can I get my symbols for Diameter, Degree, Plate, Centerline. I used to be able to type a code to get these symbols to appear in ACAD. Can someone please help me with this.
3 REPLIES 3
in reply to: seferj
Use the Windows Character Map, find the symbol you want, and copy/paste into
your project, or find the ALT code and type it using the number pad.
wrote in message news:5421924@discussion.autodesk.com...
Joe.Charpentier
in reply to: seferj
The control codes used for shx fonts are not equivalent to the control codes for True type fonts. Also, remember that many of these special characters in the shx fonts (plate and centerline, for instance) are not standard in true type fonts. AutoCAD was providing WYSIWYG text back in the DOS days, long before there were widely used standards for these things. Therefore, Autodesk was free to create its own fonts and let users modify them as the wished. For better or for worse, Revit is a Windows program, and therefore uses true type.
If anyone knows of a true type font that includes these symbols, let us know....
BrentS
in reply to: seferj
Alt + 216 = dia symbol
Alt+ 176 = degree symbol
In revit under the drafting tab click 'symbol' then you can load centreline from there and also make your own plate symbol by duplicating and editing the centreline family
