Hi Everyone, hope you're all doing well.
When discovering REVIT Structure 2013, i met some "problems" if we can call it like this. Those problem are :
1/ With Slabs, i want to show 2 differents textures: Blank one for directionnal slab and a "Concrete" like one for bidirectionnal slabs, the problem is that the graphic that we can edit in each view is working for all the family (Slabs Here) without differencing between 2 types of the same family.
2/ It may be very obvious and i just don't see it but, is there any way to make a slab bidirectionnal : a concrete slab that's supported in 4 beams or any other kind of vertical support.
3/ In some cases, when using analytical Editing on Slabs, a discontinuous line (that shows limits of the Slab) are showing inside of the beams that support the slab, i tried to hide it but with no results
Here is a screenshot that shows what i mean in 1/ and 3/
Please help me and sorry if those questions seems obvious, i'm starting in RST 2013.
Thanks in Advance ^^
Any help guys? ^^'
at least if anyone have a hint somewhere i'll read everything that concern my questions !!
