Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
sloped wall opening
4 REPLIES 4
DParkRMAK
3012 Views, 4 Replies
sloped wall opening
Hi, Revit structure 2013 -  I have several sloped walls that I created with the mass wall tool. I need to create openings in these walls so I created a void form in my mass object then created my walls. The void is created perpendicular to the face of the wall but when I create the wall the opening top and bottom is parallell with the floor plane. Is there a way to keep it from doing this? I need the hole to be perpendicular to the faces of the wall.
I tried to use the opening by face tool but I am unable to select the face of the sloped wall.
4 REPLIES 4
lanl
in reply to: DParkRMAK
Hi DParkRMAK,
If you want to add an opening on the sloped wall, you can create another in-place wall component to cut the sloped wall:
1.Click “Home”- -“Component”- -“Model In Place”, set Family Category as Wall
2.Click “Void Forms”, create a void as the opening, before doing this, set the sloped wall face as Work Plane (Pick a plane)
3.After finishing the void, click “Modify”- -“Cut”- -“Cut Geometry”, select the sloped wall firstly, then select the void.
4.Click Finish
Or in step 2 in model in place editor, you can try click “Opening”, then select the sloped wall when asking to pick the host, then draw the opening, click Finish.
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
DParkRMAK
in reply to: lanl
Thanks, That did the trick. I had to do the same thing for the top of the wall because it also defaulted to parallel with the floor plane.
I had tried this solution before but what I was missing was selecting the object to be cut while I was in the model in place mode. I didn't think I was able to select other objects and it wouldn't let me create just a void. This should work with the rafter cut question I Posted before.
DParkRMAK
in reply to: lanl
Why doesn't this same method work with beams?
With the wall I was able to select the wall to do the void cut while I was in the model in place space but with the same procedure I am unable to select beams.
MKrickS4URW
in reply to: lanl
Worked perfectly, Thanks
@lanl wrote:
Hi DParkRMAK,
4.Click Finish
Thanks.
@lanl wrote:
Hi DParkRMAK,
4.Click Finish
Thanks.
