Revit Structure
Revit Structure
Distinguished Contributor
DParkRMAK
Message 1 of 3 (463 Views)
Show beam and joist extensions in structural framing plan views
463 Views, 2 Replies
09-06-2012 10:45 AM
 I want to be able to show roof joist extensions in my roof framing plan but I can't seem to get them to show. I added lines in my joist family constrained to the extensions and they just don't show. Others in this office have always just drawn in lines manually to show extensions. There must be a way.
Product Support
Chris.Aquino
Message 2 of 3 (425 Views)
Re: Show beam and joist extensions in structural framing plan views
09-17-2012 08:02 AM in reply to: DParkRMAK
To help troubleshoot this issue, would it possible to post one of the families your are working with?
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
DParkRMAK
Message 3 of 3 (409 Views)
09-18-2012 06:15 PM in reply to: Chris.Aquino
This is the case with all out of the box beams and bar joists etc. What I did was I constrained the symbolic line to the top chord extrusion and converted the symbolic line to a model line and it showed up in my roof framing plan. I added  a parameter to adjust the length of the line to make it show the way I wanted and set visibility settings so it only shows in plan.
Normally the extensions do'nt need to show but in this case I had a 4' extension beyond the beams to slose the roof at the ridge and other extensions to catch SIP panels.
