Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Sheet Piled Wall
3 REPLIES 3
924 Views, 3 Replies
Sheet Piled Wall
I am trying to create a sheet piled wall next to a river. Does anyone know if there are standard UK sheet pile families available for use.
Thanks, Andy
3 REPLIES 3
I think you missed the point slightly. I not trying to actually build the wall but only draw the wall in revit. I was hoping that someone had some pile profiles so i could create the pile family. thanks anyway for the reply.
Tom_Kunsman
Could you not create the profiles yourself? I have seen lots of AutoCAD profiles for sheet pile. If you have those, creating them in Revit would be easy. Does not seem like many people are modeling sheet pile in Revit.
If you create them then you can upload them for others to use 🙂
chrisplyler
in reply to: Tom_Kunsman
Not piles, but I made R-panels by drawing a profile in a curtain panel family, then using a curtain wall with no mullions and no gap. You could basically do the same thing.
xtn
