I am trying to draw a section along the length of a strip found to show the steps. in order for the section to show the foundations hatched, i need to have the section marks within the line of the foundation. is there a way to offset the section marks from the foundation line but still have the hatching showing. similar to how a framing elevation allows the indicator line to be moved away from the elevation origin
Andy
Solved by Melnyk. Go to Solution.
Hmm .. you're trying to create a section that doesn't cut the foundation. Why not paint the surface (Modify ->Paint)?
I am trying to get a section along the foundation (see attached plan) but i don't really want the section line where shown. i would prefer it where the elevation marker is. The ideal output would be similar to the section view. It may be that I will need to play with a surface pattern but I was hoping to avoid some extra work.
