hello
i want to know if there is a possibility to calculate how many brick in a wall and how can create such type of wall
please can some one help me
Hi fayforum,
It is difficult to create such a wall directly with the Wall function in Revit. If you want to calculate how many brick in a wall, you can add a project parameter for the wall category "brick number per volume of wall", set its value based on the brick style, and try to add a Calculated Value in wall schedule using formula (you can use parameter wall volume, or wall area, thickness, etc in formula) to get a rough number for the brick in the wal.
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Thank you very much for your answer, please i'm beginner in revit and i hope you can explain me if you can in video please because its very important please help me
Hi ff, if you are looking for a quick solution:
- calculate manually the amount of bricks per area or volume
- select your wall and look in properties box the for the area or volume and do some multiplication
- if you have several walls create a wall schedule to get the total area and volume
As you see there can be several solutions depending on what you actually want to achieve. Have a nice time testing!
Hi fayforum,
I created a short video to show the basic steps:
http://screencast.com/t/0daBgBMDZ
Note: in the video, I create a calculated value "brick number", and its formula is "(Volume/1/1/1)*brcik number per volume". I use Volume/1/1/1 is to delete the volume units, cause the brick number is a integer, it is unitless, otherwise, it will tell you inconsistent unit.
Thanks.
