Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rvit structure walls
4 REPLIES 4
425 Views, 4 Replies
hello
i want to know if there is a possibility to calculate how many brick in a wall and how can create such type of wall
please can some one help me
4 REPLIES 4
lanl
Hi fayforum,
It is difficult to create such a wall directly with the Wall function in Revit. If you want to calculate how many brick in a wall, you can add a project parameter for the wall category "brick number per volume of wall",  set its value based on the brick style, and try to add a Calculated Value in wall schedule using formula (you can use parameter wall volume, or wall area, thickness, etc in formula) to get a rough number for the brick in the wal.
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Lei Lan
in reply to: lanl
Thank you very much for your answer, please i'm beginner in revit and i hope you can explain me if you can in video please because its very important please help me
awes
Hi ff, if you are looking for a quick solution:
- calculate manually the amount of bricks per area or volume
- select your wall and look in properties box the for the area or volume and do some multiplication
- if you have several walls create a wall schedule to get the total area and volume
As you see there can be several solutions depending on what you actually want to achieve. Have a nice time testing!
lanl
Hi fayforum,
I created a short video to show the basic steps:
http://screencast.com/t/0daBgBMDZ
Note: in the video, I create a calculated value "brick number", and its formula is "(Volume/1/1/1)*brcik number per volume". I use Volume/1/1/1 is to delete the volume units, cause the brick number is a integer, it is unitless, otherwise, it will tell you inconsistent unit.
Thanks.
Lei Lan
