Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Robot Structural Analysis Link 2014
14 REPLIES 14
Message 1 of 15
e-max_ing
12097 Views, 14 Replies
Install Revit from  Building Design Suite premium and moreover Professional Robot Structural Analysis, in the analysis tab in Revit, I only see "Reinsforcement check code", does not seem "Link Robot Structural Analysis", as active?
14 REPLIES 14
Message 2 of 15
hungn
in reply to: e-max_ing
You need to download and install
Structural Analysis and Code Checking Toolkit 2014
http://apps.exchange.autodesk.com/RVT/Detail/Index?id=appstore.exchange.autodesk.com%3astructuralana...
Hung Nguyen
Cansel
Message 3 of 15
e-max_ing
in reply to: hungn
Tanks
Message 4 of 15
oliveirajr.om
Thanks man!
Message 5 of 15
in reply to: hungn
I am looking for the 2013 structural analysis addin for revit 2013, is a version avaialable??
Message 6 of 15
Max.Kotsar
Hi, Malcolangelo!
See this topic
Max Kotsar
Сообщение полезно - Проблема решена -
Message 7 of 15
sambolokro
is true, you should to install the add
Message 8 of 15
in reply to: hungn
Ok , Thank you
Message 9 of 15
shubham_shri
No, Its not available now on the website
Shubham Shrivastava
Autodesk Certified Professional for Revit Architecture
If you find my post helpful, feel free to give Kudos
Message 10 of 15
gainerp
in reply to: shubham_shri
Thanks for sharing the link.
Message 11 of 15
skonomah247
in reply to: hungn
I CANT SEE THE ROBOT LINK IN THE AUTODESK REVIT 2018 VERSION UNDER THE ANALYZE TAB.
Hung Nguyen
Cansel
Hung Nguyen
Cansel
Message 12 of 15
skonomah247
in reply to: hungn
THANKS VERY MUCH IT WAS VERY HELPFUL
Message 13 of 15
DarrenP
in reply to: skonomah247
did you install this add in:
https://apps.autodesk.com/RVT/en/Detail/Index?id=4901636995211349921&appLang=en&os=Win64
DarrenP
Message 14 of 15
vmubuu
Need Urgent Help Please
I have Robot Structural Analysis 2014 and Revit 2017 installed on my PC but I cant find the link which will help me export and Import Structural Models between the to applications.
Even after installing the Tool Kid which contain the Link, no link was visible
Will I be able to import and export Structural Models between the two applications of two different versions 2014 and 2017 ?
Message 15 of 15
vmubuu
in reply to: vmubuu
Robot Structural Analysis link is finally appearing in the Revit Application installed on my PC and all is working properly
Thankx
