I keep getting this error message when adding spot levels. Not all the time but randomly it will freeze then ask to save!
but if i save using the promt button, revit crashes. If i hit escape and save it normally it continues to work fine until the next spot level serious error!!
Any ideas??
John
Senior Structural Technician.
Solved by Thomas_RevitDE. Go to Solution.
Hi John,
their is an Hotfix avaiable for this issue.
Hotfix - Autodesk Revit 2013 - Spot Elevation
This Hotfix will only work, if you have Revit installed with english language.
