Can anybody post the PDF file for Revit STRUCTURE Families Guide? or provide a link to it that really works? The help documents say that there should be an option for Families Guide under the Help menu of Revit, but I don't see that option. I have the other two documents, the architectural and MEP, but I would like to have the STRUCTURE version in PDF format, too. Anybody?
For Revit versions starting in 2012 to present, the resource that is available as a family guide is located at:
For versions older than 2012, you would need to go to this file directory and locate the associated .pdf:
C:\Program Files\Autodesk Revit Product Name\Program folder
There are currently no seperate guides for Structure, MEP, or Architecture available; everything is condensed under "creating loadable families" within Revit Help. What is the version of Revit Structure that you are trying to find a .pdf for?
