Hello everyone.
Before I explain my problem, please be gentle. I'm a civil engineer that has played around with Revit like two or three times. I primarily use Civil 3D.
With that being said, I heard that you can take Civil 3D surfaces into Revit using the Bridge Extension. I have the Infrastructure Design Suite Ultimate and that comes with Revit Structure. So I downloaded and installed the extensions from the subscription website. Nothing showed up in Revit after installing it (there should be an Extension tab on the ribbon, right?). I thought, perhaps I need to update Revit first so I installed the service pack. Still nothing.
I've searched the web and the discussion group without any solution.
Any ideas, thoughts, ponderances, solutions, answers...
And, please, use small words. As I said before, I'm very Revit ignorant.
Solved by Joe.Charpentier. Go to Solution.
yes you are correct there should have been an extentions tab created in the ribbon
DarrenP
i would try to uninstall/reinstall the revit extentions
DarrenP
I restarted the computer, uninstalled, restarted the computer, reinstalled, and still nothing. I shouldn't have to do anything after installing it other than launching Revit, right?
Could it have something to do with it being part of the Infrastructure Design Suite?
Another thing, when I initially installed it, I hadn't updated to the current update, could that be an issue?
yes you shouldn't have to do anything else
i don't think so Revit Structure is Revit Structure with or without the suite i could be wrong
don't think so the extentions doesn't require the latest update to be installed it wouldn't hurt to install it anyway then try to install the the extensions again
i'll keep looking for more solutions
DarrenP
I have the update installed. That's one of the first trouble shooting things I did.
Do you see any files with the .addin extension in the folder:
C:\ProgramData\Autodesk\Revit\Addins\2013?
If not, look for one (or any of) the following files, depending on your flavor of Revit:
Autodesk.RevitExtensions.Revit.addin
Autodesk.RevitArchitectureExtensions.Revit.addin
Autodesk.RevitMEPExtensions.Revit.addin
Autodesk.RevitStructureExtensions.Revit.addin
Any Addin files found here will be applied for all users of the computer.
In addition, there are also addin files *per user* in:
C:\Users\<UserName>\AppData\Roaming\Autodesk\Revit\Addins\2013
I would suggest moving any addin files to the location for all users.
Joe
Here are the .addin files I see in the first location: HERE. Doesn't look as though any of those have to do with the extension. One is for Navis Works (I assume) and the other for Chronicle (a utility from LABS)
Additionally, there are no .addin files found in the user directory you specified. (C:\Users\bhailey\AppData\Roaming\Autodesk\Revit\Addins\2013).
@BrianHailey wrote:Here are the .addin files I see in the first location: HERE. Doesn't look as though any of those have to do with the extension. One is for Navis Works (I assume)
the link doesn't work
DarrenP
nevermind
DarrenP
You must have tried it just after I posted it. I noticed it didn't work as well so I fixed it.
You're fast!
it doesn't seem to be installing the extenstions correctly on this machine
does the install work on other machines?
DarrenP
if it does you can try copying those .addin files from that machine to your machine
DarrenP
Perhaps I got a bad download. I'll try again.
There should be two downloads for the Extensions for r2013. The second is marked "q3" and is the most recent. Is that the one you are using?
You need to install the original release of the 2013 extensions and then the Q3 release.
Joe
Aha! See, there was nothing there that said you need to install both of them so I just went with the latest one. I figured it was like a service pack, you only need the latest one (at least that's the way it is for Civil 3D). Downloading now. I'll let you know the results.
@JOE-Charpentier wrote:There should be two downloads for the Extensions for r2013. The second is marked "q3" and is the most recent. Is that the one you are using?
Joe
That was it! Thanks so much!
I hang my head in shame for not realizing this.
i guess i should of started with the easy questions first
DarrenP
Don't feel bad- the only reason I know this is I did it myself.
Sorry it took so long.
Joe
Do you using extension Civil 3D Surface to Revit is For what? I think you using for topo surface, thus why you can't find out from extension. You go and search topo robbin tap. I think is right.
