Revit Structure
Revit Structure
BrianHailey
Message 1 of 20 (1,811 Views)
Revit Structure Extensions Not Showing Up
1811 Views, 19 Replies
12-10-2012 09:17 AM
Hello everyone.
Before I explain my problem, please be gentle. I'm a civil engineer that has played around with Revit like two or three times. I primarily use Civil 3D.
With that being said, I heard that you can take Civil 3D surfaces into Revit using the Bridge Extension. I have the Infrastructure Design Suite Ultimate and that comes with Revit Structure. So I downloaded and installed the extensions from the subscription website. Nothing showed up in Revit after installing it (there should be an Extension tab on the ribbon, right?). I thought, perhaps I need to update Revit first so I installed the service pack. Still nothing.
I've searched the web and the discussion group without any solution.
Any ideas, thoughts, ponderances, solutions, answers...
And, please, use small words. As I said before, I'm very Revit ignorant.
Ribbon Screenshot
About
Brian Hailey
CAD-1.com
My Blog
DarrenP
Message 2 of 20 (1,802 Views)
Re: Revit Structure Extensions Not Showing Up
12-10-2012 11:40 AM in reply to: BrianHailey
yes you are correct there should have been an extentions tab created in the ribbon
DarrenP
Message 3 of 20 (1,800 Views)
12-10-2012 11:43 AM in reply to: DarrenP
i would try to uninstall/reinstall the revit extentions
BrianHailey
Message 4 of 20 (1,792 Views)
12-10-2012 12:46 PM in reply to: DarrenP
I restarted the computer, uninstalled, restarted the computer, reinstalled, and still nothing. I shouldn't have to do anything after installing it other than launching Revit, right?
Could it have something to do with it being part of the Infrastructure Design Suite?
Another thing, when I initially installed it, I hadn't updated to the current update, could that be an issue?
Brian Hailey
CAD-1.com
My Blog
DarrenP
Message 5 of 20 (1,787 Views)
12-10-2012 01:01 PM in reply to: BrianHailey
yes you shouldn't have to do anything else
i don't think so Revit Structure is Revit Structure with or without the suite i could be wrong
don't think so the extentions doesn't require the latest update to be installed  it wouldn't hurt to install it anyway then try to install the the extensions again
i'll keep looking for more solutions
BrianHailey
Message 6 of 20 (1,782 Views)
12-10-2012 01:07 PM in reply to: DarrenP
I have the update installed. That's one of the first trouble shooting things I did.
Brian Hailey
CAD-1.com
My Blog
Employee
Joe.Charpentier
Message 7 of 20 (1,770 Views)
12-11-2012 07:16 AM in reply to: BrianHailey
Do you see any files with the .addin extension in the folder:
C:\ProgramData\Autodesk\Revit\Addins\2013?
If not, look for one (or any of) the following files, depending on your flavor of Revit:
Autodesk.RevitExtensions.Revit.addin
Autodesk.RevitArchitectureExtensions.Revit.addin
Autodesk.RevitMEPExtensions.Revit.addin
Autodesk.RevitStructureExtensions.Revit.addin
Any Addin files found here will be applied for all users of the computer.
In addition, there are also addin files *per user* in:
C:\Users\<UserName>\AppData\Roaming\Autodesk\Revit\Addins\2013
I would suggest moving any addin files to the location for all users.
Joe
BrianHailey
Message 8 of 20 (1,755 Views)
12-12-2012 11:14 AM in reply to: Joe.Charpentier
Here are the .addin files I see in the first location: HERE. Doesn't look as though any of those have to do with the extension. One is for Navis Works (I assume) and the other for Chronicle (a utility from LABS)
Additionally, there are no .addin files found in the user directory you specified. (C:\Users\bhailey\AppData\Roaming\Autodesk\Revit\Addins\2013).
Brian Hailey
CAD-1.com
My Blog
DarrenP
Message 9 of 20 (1,750 Views)
12-12-2012 11:18 AM in reply to: BrianHailey
the link doesn't work
DarrenP
Message 10 of 20 (1,748 Views)
12-12-2012 11:18 AM in reply to: DarrenP
nevermind
