If you using Metric Values as family type name
Then you could start with M_ for metric
You should mention the company name. to be able to find your families in a collaboration project
M_Company_
Then The discipline ELE, MEC, STR, ARCH,
M_Company_Str_
Then the Material + element name
M_COMPANY_STR_Steel_Beam_
OminClass number could be useful for different project
M_COMPANY_STR_Steel_Beam_23.25.30.11.14.14
And after finishing each project you could export all the famillies used under a new Project family Folder. Sometimes it is easier to remember used famillies under specific project folder.
You Could Use D for detail in the beginning of the family D_M_....
If ever you want to export all families you could differentiate between model and detail family
Thanks for the reply. After working ours out, we ended up with a much simpler coding system. It's intended for internal use, not as a shared thing, so we don't need the company specific stuff. It boiled down to using the coding to define material, material type, and what level it occurs on. We are using a start-up view that has an index of this for easy reference.
The problem is when comes to big project. BIM managers from different companies get together and decide some standards to simplify the search inside the project. Some project in Canada for example, Like in Ottawa or in the French Provence Require Bilingual Naming. Other project Require Omni Class Number so sometimes it gets trickier for some specific project.
But that's what I meant in saying that this coding system was for internal use only. Outside companies or entities have no real need to know what our coding convention is because it's simply a way for our engineers and Reviteers to communicate with what typical details are needed and where they need to go. The coding system is all numerical also, no acronyms or words or phrases.
