When I try to use the Composite Beam design extension for Revit Structure 2012 I get the following error: "1 of the selected members were not recognized types and will not be designed". I have tried this with all of my members and I get the same error. I am using a simple W shape beam and can't seem to get past this error.
Solved by jmmeagher. Go to Solution.
The withepaper and the movie below should help you, if not please send us you rvt file for deep analysis
http://www.ideateinc.com/whitepapers/bim/autodeskrobot_revitstructure_whitepaper.pdf
http://students.autodesk.com/ama/orig/structural_eng_2011/assets/videos/Ex_4-1_COMPOSITE-BEAM.mp4
Thanks. I actually realized that there was an update to the Revit Extensions and once I downloaded the new update it seems to have taken care of the issue.
Thanks for your feed-back
