Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit STRUCTURE Books
3 REPLIES 3
cemnet
10347 Views, 3 Replies
Hi everyone, I'm looking for a good book about Revit STRUCTURE. When I search online I can find many book for Revit Arch but not Structure. Thank you for any help.
3 REPLIES 3
in reply to: cemnet
This sounds about right, but there are some materials out there. Some that I found are:
"Revit Structure 2014 Basics: Framing and Documentation" by Elise Moss
"Exploring Autodesk Revit Structure 2014" by Prof. Sham Tickoo
"Learning Revit Structure 2014 - Training DVD" by Infinite Skills
"Learning Advanced Revit Structure 2014 - Training DVD" by Infinite Skills
I haven't personally looked through them, so I can't speak to their quality. I'm not sure how elaborate you're looking for, but these are some that you can look into. There's also "Mastering Revit Structure" that used to come out with the older versions, but I'm not sure if they made one for 2014. If you can find one for cheap, you might still be able to use these at a conceptual, ground-level start. Some of the finer points of Revit have changed with the newer versions, but many of the basics remain unchanged. Hope this helps
cemnet
Thank you very much!!
praveen455
in reply to: cemnet
revit structure books which are effordable
http://www.cadcim.com/ProductDetails.aspx?ISBN=978-1-936646-79-1
http://ebook.cadcim.com/product/exploring-autodesk-revit-structure-2014
Good videos on youtube channel
https://www.youtube.com/channel/UCptWDQBmKAdtb7Au3lHeoGg
Online material available for revit structure for 2010 & 2009 versions check it
