My office is considering the move to Revit. I am comparing Revit Structure 2014 to Revit 2014 (all in one) contained in the Building Design Suite.
I just need to confirm if the structural functionality in Revit 2014 is the same and as complete as the stand alone Revit Structure 2014.
Any insight would be appreciated.
Solved by KateMorricalTowne. Go to Solution.
You can buy individual flavors of Revit separately, but Autodesk hasn't made it very cost-effective anymore. Check out the prices on the store: http://www.autodesk.com/store/all-products
If you buy the Building Design Suite Premium, you get all the flavors of Revit in one installation plus a whole bunch of other stuff (AutoCAD, Showcase, etc.)
From a user perspective, Revit 2014 and Revit Structure 2014 are practically indistinguishable.
The structural capabilities are the same. I've run into this because our company is vacillating on which suite to buy next: Infrastructure, Plant, or Building. Only Building Design Suite includes the full featured version of REVIT. There are rare occasions where using the other tool palettes would be nice, cable tray routing from the Systems tab is a good example.
Dear Sir,
I will need a autodesk Revit architecture & revit structure book if possible to download the old version 2014,2015,2016,2017 it possible through internet free downloaded
If you knows Link kindly share.
Deepak.S,
