Hi
I am making some rebar shapes and I have a problem regarding "Hook at start" and "Hook at end". I want to choose 0°, but thats not an option.
And I have also tried do define new rebar hooks, but the lowest degrees is 1°. The minimum Extension Multiplier value is alse limited to 0.01. These parameters have an impact in schedule when using built-in-parameters like "Bar length", which basicually calculates length +/- bends.
Does anyone have a solution for this?
Thanks alot!
- Norwegian
Solved by esplof. Go to Solution.
Hi Ewa,
The norwegian standard has some rules regarding coding system in the bending list.
0 = No end hook
1 = end hook 90°
2 = End hook between 90°and 180°
3 = End hook 180°
So i want the rebar schedule to say "0" when there is no hook, without disrupting the calculation of "bar length" I hope that clarifies it 🙂
- Espen
I have manage to "cheat" this problem. I was wrong about the lowest degree input in "Rebar Hook Type Properties" Actually you are allowed to use as low as "0.001°", se included pictures. If anyone has a better solution to this, it would be appreciated 🙂 Maybe if its possible to edit "Bar Length"-formula.
vdfvd
Yes this is the way I've been doing it. The "hook" is too small to affect the bar length and we avoid the dreaded "none" in the Norwegian bending schedule.
