Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
revit extensions - load takedown
12 REPLIES 12
Message 1 of 13
00alberto
1882 Views, 12 Replies
I tried several times  to use the "load takedown" extensions with revit structure 2012x64, but i couldn't.
The structure defined in rst is simply not exported, and the structure in the extension is blank, with no elements, no levels, nothing. see pic.
Did anyone try to use this extension?
12 REPLIES 12
Message 2 of 13
jad.dellel
in reply to: 00alberto
Yes It works fine, but you should have Autodesk Robot Structural Analysis (RSA) 2012 installed.
Regards.
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Message 3 of 13
00alberto
I forgot to mention it... I also have RSAP2012 installed. but it doesn't work.
How can you import the structure from rst into the extension? shouldn't the process be automatic?
Message 4 of 13
jad.dellel
The load takedown should work automatically, in fact It uses a feature of RSA called Autodesk Concrete Building Structures, can you check please if it's also installed.
Jad DELLEL
Message 5 of 13
00alberto
in reply to: jad.dellel
yes, both CBS and RSAP 2012 (64 bit) are installed.
I also noticed a problem with the "Reinforcement code check" extension: it says that RSA 2012 is not installed.
All the other extensions (Robot and CBS link, slab analysis, beam analysis, etc) work well.
Message 6 of 13
jad.dellel
Try to launch both RSA and CBS first.
Jad DELLEL
Message 7 of 13
00alberto
I did. RSA and CBS open, but load takedown extension still not working.
Maybe i should uninstall and reinstall everything again?
Message 8 of 13
jad.dellel
Try first to register RSA components neither reinstall and let us know if it works.
Jad DELLEL
Message 9 of 13
ksmith95
I am having this same problem.  Did you figure out a solution?
Message 10 of 13
jad.dellel
in reply to: ksmith95
Hi Guys,
If you're using Windows 7 or Vista, turn off the User Account Control (UAC)
Jad DELLEL
Message 11 of 13
ksmith95
I just checked and my User Account Control is turned off.  But I'm still having the same problem.  Any other suggestions?
Message 12 of 13
ksmith95
I just realized there is a Q3 Update for the Autodesk Revit Extensions for Revit Structure.  I got it installed and it seems to have fixed the issue I was having.
Message 13 of 13
jad.dellel
Thank you very much for your feedback.
I give you kudo for sharing this info.
Jad DELLEL
Rail Community
