I'm getting this error when trying to reinforce some of the columns in my project:
Create method exception.
Assembly name: DReinfColumn: Disabled Analytical Model can't be used.; StackTrace: at Autodesk.Revit.DB.Structure.Ana ...
REX: Engine version: 2014; Version name: ; Culture info: en-US PLATFORM: Win32NT Microsoft Windows NT 6.1.7601 Service Pack 1 SOURCE: AREX MESSAGE: (02-07-2013 9:35:25) Create method exception. Assembly name: DReinfColumn: Disabled Analytical Model can't be used.; StackTrace: at Autodesk.Revit.DB.Structure.AnalyticalModel.GetPoint() at REX.Common.Revit.Geometry.REXAnalyseElement.REXFoundation.RunModel(Options geoOptions, FamilyInstance fInstance, REXAnalizeType analizeType) at REX.Common.Revit.Geometry.REXAnalyseElement.GetElemConcrete(Element familyInst, Boolean analyzeInstance, Boolean originalGeometry) at REX.Common.Revit.Concrete.REXElementMngr.GetGeomParamSupport(GroupElement data, REXPlaceSupport placeSupport) at REX.Common.Revit.Concrete.REXElementMngr.Analize(Boolean suppAnalize, REXPlaceSupport placeSupport, Dictionary`2 neighbours) at REX.DReinfColumn.ReinfFactoryRevit.OnInitialize(String runContext) at REX.DReinfColumn.ReinfFactoryRevit.OnCreate() at REX.Common.REXExtension.Create() at REX.DReinfColumn.Extension.Create() at REX.Common.REXApplication.Create(REXContext& AppContext) DEPENDENCY: Autodesk.REX.Framework, Version=1.0.0.0, Culture=neutral, PublicKeyToken=51e16e3b26b42eda (file version: 2012.0.0.1769) | REX.Controls, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Controls.WPF, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Controls.Forms, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Mathematics, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Preferences, Version=2014.0.0.2609, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2609) | REX.System, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) | REX.Service, Version=2014.0.0.2608, Culture=neutral, PublicKeyToken=null (file version: 2014.0.0.2608) LAST ENTRIES: 4 / 1155 1154: (02-07-2013 9:35:06) AREX.REX.Foundation - Create method exception. Assembly name: DReinfColumn: Disabled Analytical Model can't be used.; StackTrace: at Autodesk.Revit.DB.Structure.AnalyticalModel.GetPoint() at REX.Common.Revit.Geometry.REXAnalyseElement.REXFoundation.RunModel(Options geoOptions, FamilyInstance fInstance, REXAnalizeType analizeType) at REX.Common.Revit.Geometry.REXAnalyseElement.GetElemConcrete(Element familyInst, Boolean analyzeInstance, Boolean originalGeometry) at REX.Common.Revit.Concrete.REXElementMngr.GetGeomParamSupport(GroupElement data, REXPlaceSupport placeSupport) at REX.Common.Revit.Concrete.REXElementMngr.Analize(Boolean suppAnalize, REXPlaceSupport placeSupport, Dictionary`2 neighbours) at REX.DReinfColumn.ReinfFactoryRevit.OnInitialize(String runContext) at REX.DReinfColumn.ReinfFactoryRevit.OnCreate() at REX.Common.REXExtension.Create() at REX.DReinfColumn.Extension.Create() at REX.Common.REXApplication.Create(REXContext& AppContext) 1153: (02-07-2013 9:33:59) AREX.REX.Foundation - Create method exception. Assembly name: DReinfColumn: Disabled Analytical Model can't be used.; StackTrace: at Autodesk.Revit.DB.Structure.AnalyticalModel.GetPoint() at REX.Common.Revit.Geometry.REXAnalyseElement.REXFoundation.RunModel(Options geoOptions, FamilyInstance fInstance, REXAnalizeType analizeType) at REX.Common.Revit.Geometry.REXAnalyseElement.GetElemConcrete(Element familyInst, Boolean analyzeInstance, Boolean originalGeometry) at REX.Common.Revit.Concrete.REXElementMngr.GetGeomParamSupport(GroupElement data, REXPlaceSupport placeSupport) at REX.Common.Revit.Concrete.REXElementMngr.Analize(Boolean suppAnalize, REXPlaceSupport placeSupport, Dictionary`2 neighbours) at REX.DReinfColumn.ReinfFactoryRevit.OnInitialize(String runContext) at REX.DReinfColumn.ReinfFactoryRevit.OnCreate() at REX.Common.REXExtension.Create() at REX.DReinfColumn.Extension.Create() at REX.Common.REXApplication.Create(REXContext& AppContext) 1152: (02-07-2013 9:32:07) AREX.REX.Foundation - Create method exception. Assembly name: DReinfColumn: Disabled Analytical Model can't be used.; StackTrace: at Autodesk.Revit.DB.Structure.AnalyticalModel.GetPoint() at REX.Common.Revit.Geometry.REXAnalyseElement.REXFoundation.RunModel(Options geoOptions, FamilyInstance fInstance, REXAnalizeType analizeType) at REX.Common.Revit.Geometry.REXAnalyseElement.GetElemConcrete(Element familyInst, Boolean analyzeInstance, Boolean originalGeometry) at REX.Common.Revit.Concrete.REXElementMngr.GetGeomParamSupport(GroupElement data, REXPlaceSupport placeSupport) at REX.Common.Revit.Concrete.REXElementMngr.Analize(Boolean suppAnalize, REXPlaceSupport placeSupport, Dictionary`2 neighbours) at REX.DReinfColumn.ReinfFactoryRevit.OnInitialize(String runContext) at REX.DReinfColumn.ReinfFactoryRevit.OnCreate() at REX.Common.REXExtension.Create() at REX.DReinfColumn.Extension.Create() at REX.Common.REXApplication.Create(REXContext& AppContext) 1151: (02-07-2013 9:28:44) AREX.REX.Foundation - Create method exception. Assembly name: DReinfColumn: Disabled Analytical Model can't be used.; StackTrace: at Autodesk.Revit.DB.Structure.AnalyticalModel.GetPoint() at REX.Common.Revit.Geometry.REXAnalyseElement.REXFoundation.RunModel(Options geoOptions, FamilyInstance fInstance, REXAnalizeType analizeType) at REX.Common.Revit.Geometry.REXAnalyseElement.GetElemConcrete(Element familyInst, Boolean analyzeInstance, Boolean originalGeometry) at REX.Common.Revit.Concrete.REXElementMngr.GetGeomParamSupport(GroupElement data, REXPlaceSupport placeSupport) at REX.Common.Revit.Concrete.REXElementMngr.Analize(Boolean suppAnalize, REXPlaceSupport placeSupport, Dictionary`2 neighbours) at REX.DReinfColumn.ReinfFactoryRevit.OnInitialize(String runContext) at REX.DReinfColumn.ReinfFactoryRevit.OnCreate() at REX.Common.REXExtension.Create() at REX.DReinfColumn.Extension.Create() at REX.Common.REXApplication.Create(REXContext& AppContext)
Has this ever happened to you? This happens in some of the columns in my project, not all of them, but I can't figure out the pattern...
still the same problem here. using Revit Structure 2014. already updated to update2 but with no luck. any solution?
