Any thoughts on how to make this connection?
Revit Extension doen't create connection between a HSS column and a W flange beam. Autodesk forum also says that, Revit Extension does not create connection between those.
If you have Robot or ASD, it is where i would create my connections in. not model it in Revit
You can detail the connection in 2D in Revit and call it up or create it in Robot and pull it back into Revit
ASD can create the connection but i have only been able to pull steel profiles back into Revit, not the plates and bolts.
Regards
