I tried several times to use the "load takedown" extensions with revit structure 2012x64, but i couldn't.
The structure defined in rst is simply not exported, and the structure in the extension is blank, with no elements, no levels, nothing. see pic.
Did anyone try to use this extension?
It works well, but you need to have Robot Structural Analysis installed and specially its component Autodesk Concrete Building Structure.
Please read the end of this discussion, It should help you:
http://forums.autodesk.com/t5/Autodesk-Revit-Structure/revit-extensions-load-takedown/td-p/3139074
