Hi !
We have Revit Structure-2010 and want to model Automatic Reinforcement In The Structural Elements Like Column, Footing Beams, etc.
Is there any Extension is available which will be having above mentioned options ??
Kindly inform the names OR Links as early as possible.
If you are on subscription, the extensions for reinforcement creation are available in the subscription center on the Autodesk website.
Joe
its called subscription advantage pack for Revit Structure 2010
DarrenP
