Hello. I have already post something like this before, but the issue is still not solved. Again, I cannot install Revit 2015. After waiting for three hours, this is what I get. I badly need the program and I will really appreciate if someone will be able to help me. Attached here is the installation log file which I saved after the installing failed.
Install Autodesk® Revit® 2015 Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
