Hi we Have been using Revit Structure 2013 on some projects and recently downloaded a copy of Revit LT (2014) for evaluation which appears to have corrupted the full version of Revit as now the slab edit command does not appear to be working properly. Sometimes the edit tool is not visible and sometimes the tick or cross on completion is not visible, using the minimize to tabs can make them reappear.
Any advice would be appreciated.
Solved by Joe.Charpentier. Go to Solution.
Solved by CoreyDaun. Go to Solution.
Hello, and welcome to the forums!
This is a known issue that has come up frequently in the Revit Architecture board; follow the link below to a relevant thread there...
Please update to the latest version of Revit 2013- you must not be on the latest version.
If you have r2012, you may also have issues.
Links to updates and hotfixes, as well as a complete discription of the issue (which happens when .NET 4.5 is installed) can be found on the Revit Clinic site:
Joe
