Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revision Number
6 REPLIES 6
elbeiser
602 Views, 6 Replies
Revision Number
I want to begin my revision number by 0 (zero) and not by 1 (one) ....
Any ideas????
6 REPLIES 6
shiny.stephen
in reply to: elbeiser
Believe that the number sequence is hardcoded into the program. You could however create a new custom revision tag and use text instead of label, but it would not be "smart", so you´d need to manually update that parameter.
Also you could try this:
1. Change your first revision to Alphabetic.
2. Change the alphabetic sequence and insert the letter "O" at the front of the group.
3. Change the second revision to Numeric.
_____________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Shiny Stephen
Support Specialist
Product Support
Autodesk, Inc.
elbeiser
Thank you. Something for wish list.
shiny.stephen
You can provide feedback about feature enhancement through the link below. This would help us to analysis your feedback and use it for development. To provide feedback please follow the below link:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Providing feedback for the product will help the development team to review them and help them to enhance the product in future.
______________________________________________________________
Shiny Stephen
Support Specialist
Product Support
Autodesk, Inc.
kirbybeegles4894
Using the alphabetic sequense does not work.  You can't put numbers into the field.  I too would like to be able to make the first revision '0'.
elbeiser
in reply to: kirbybeegles4894
When you change to alphabetic you put the character O, that looks like 0 (zero).
brendonclark
You cant insert a 0 (number) but you can insert unicode into the alphabetic sequence. So when your ready for a zero, insert alt0216 ( Ø ) into the sequence. This is less likely to be confused with the letter O (hopefully your not upto revision O, as thats a lot of changes)
