What would be the best method to create a retaining wall with a brick face? See below for what I'm looking for.
I need a brick wall along the top of the footer 0.5" from the face of the concrete wall. I'm a novice when it comes to Revit, but know enough to get around. I first had problems trying to use the built in walls & foundations, so I made my own with a sweep & profile of the foundation and a second sweep & profile for the wall itself. So far so good, except when I try to add an architectural wall that's only the .5" air gap and 3.5" brick Revit gives me an error saying, "Highlighted walls overlap. One of them may be ignored when Revit finds room boundaries. Use Cut Geometry to embed one wall within the other." Is that because my brick wall is too close to the retaining wall itself? Is there a way to get the brick, the gap, and the sloping concrete of the wall all in one wall?
No thanks to the abysmal help in Revit, I figured out how to add a profile to a wall, but not sure how to make it work correctly. The top of the retaining wall concrete is 12", the bottom is 18", and the insertion point is from the middle of the top (6" inside from the flat side). So far the only way I see to get the .5" gap and 3.5" brick on the flat side is to add a 6" air barrier that sits in the same place as part of the concrete for the retaining wall profile. Is there another way to make the 0.5" air gap and 3.5" brick to offset 6"? Is it OK to have materials that overlap like this?
Thanks for your effort. I am also sending you Revit Files. Look what will be more helpful for you. Please find the attached files.
Subhradeep Sen
@subhra_civil wrote:Hi,
Subhradeep Sen
Thanks for that. So is it better to use a reveal instead of a sweep for sloped walls such as a retaining wall?
Thanks for your reply. Actually it depends on user. May be sweep is easy to someone or may be reveal is easier to someone. I have just shown you the process. Now use is completely upto you.
Thanks & regards,
Subhradeep Sen
Kolkata
India
I'll suggest another method that has alot more flexibility. Instead of using the typical wall tools, try creating an "in-place component." To do this, go to the Structral Tab -> Component -> Model In-Place -> and select wall. See attached image. Then model the geometry that you are creating. If this is a straight wall then you can use an extrusion. If it is a curved wall, then you can use a sweep. You can model the concrete and the brick face seperately within the same In-Place Family and give them different materials. It may also be helpful to create some reference planes before starting the In-Place Family.
This should solve your problem and provide much more flexibility.
Thanks for your reply. Can you pls send me a sample wall revit file by using "Create in Place"?????? Then i can understand what you want to say about this type of wall creating by using "Create in Place". I am awaiting for your reply.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Thanks for your reply. I am unable to open the Revit file which you have sent to me. I am Revit 2014. I think you are using 2015. Can you save this in 2014 version?????? If possible then please send me that file in Lower Version.
Thanks & regards,
Subhradeep Sen
kolkata
India
Again same problem. Send me in Revit 2014 Version.
Thanks & regards,
Subhradeep Sen
Kolkata
India
The file is in Revit 2014. I just opened it up and verified. I will attach again.
ok. I have able to opened that file. But with this family you will not able to create continuous wall. just try to create 4 nos. wall with this. you will not able to joint the wall corners.
Subhradeep Sen
This in-place family is an example of how it could be done. If you want this same wall turn around corners, then you'll create the geometry with a sweep instead of an extrusion within the in-place family.
I know that it is a Create in Place component. So that i am telling you that if you create this wall with sweep option it will not work in proper way. As per as my understanding. If it is possible by you then send me a sample file and show me how it will work in proper way.
Thanks & regards,
Subhradeep Sen
kolkata
India
Attached is an example that uses an in-place family with a sweep to create the geometry instead of an extrusion. You should see that the possibilities are limitless. This is more or less just straightforward modeling that allows you to assign a Revit category. It can be used any time the typical tools provided don't allow enough customization or flexibility.
I have seen your file. But "Create in Place" what i have seen you have to create 2 nos. different profile for every uses in sweep option or in extrusion. I think it should be better uses with wall reveal. See my attahced file which i have sent earlier to original problem sender.
Thanks & regards,
Subhradeep Sen
kolkata
India
