Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Resize top and bottom cord and web of truss.
3 REPLIES 3
sescadd
536 Views, 3 Replies
Is there a way to modify the size of the top and bottom cord and web of truss?  I see there are a few options under structural framing type, however not what I need.
3 REPLIES 3
sescadd
in reply to: sescadd
I found a site that helps some. However after I modify the truss it does not look like a finished truss due to the web of the truss is not connected to the top and bottom cords.
http://autodeskrevitvideotutorials.caddsoftsolutions.com/2011/10/autodesk-revit-structure-creating-b...
AJA14
Hi. I'm not sure I understand what you are exactly looking for. Anyways, you can easily change the framing elements that form a truss from the type properties and the rest can be maniputlated from the instance properties. You may also edit the truss and change it to any form that suits your preferences. If you provide an image, maybe it will help us assist you better.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
jad.dellel
Could you please attach your rvt file ?
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
