Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Reinforcement in Wall
6 REPLIES 6
512 Views, 6 Replies
Hi everyone.
I am using revit Structure 2014 and I just a have quik question regarding reinforcement.
I´m wondering if it´s possible to reinforce wall corners with B-shaped rebars? See the attached picture to fully understand what I mean..
thanks
Regards David
6 REPLIES 6
Alaaeldin_Alsahli
Do you have the B shape already and you need to know how to rebar the wall corner?
Or you know how to rebar a corner but you need to know how to create a B Shape?
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
in reply to: Alaaeldin_Alsahli
Yes I need to know how to rebar a wall corner.
regards David
Alaaeldin_Alsahli
When you choose the Rebar feature you need to select The sketch Rebar
Here is a video that shows how to do it
https://screencast.autodesk.com/main/details/b5d512f2-e2fc-4ec2-ace4-c4392c066a8e
Keep me posted if you need any additional information
Alaaeldin Alsahli
Alaaeldin_Alsahli
At the end of the first video I did copy it manually but you also use the Rebar set instead
Here another video that shows how to work set the rebar quantity once the rebar is modeled
https://screencast.autodesk.com/main/details/38f8e1f8-e7d2-4298-b089-7da27503d415
Alaaeldin Alsahli
Alaaeldin_Alsahli
Just a follow up to see if this helped to accept it as a solution to help other with same question to find it
Alaaeldin Alsahli
Hi
Thank you for the solution, works great!
Regards David
