Hi, I was wondering if I could create a family that cuts a recess in the slab and if I can have this recess as a variable depth. Is there a way to create a variable parameter similar to slabs and check it when i want the recess to be variable and vice versa. Or should I simply create an opening and then create a variable depth slab in its place. Thanks in advance.
Solved by raghavendrabhat6624. Go to Solution.
create new family using "Metric Generic Model floor based.rft" add a void of the required size in the family slab and then insert it in the project.
tip: You can make the void parametric if you know how to play with parameters and reference planes.
