Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar Tags
4 REPLIES 4
stewartg
3631 Views, 4 Replies
Rebar Tags
Hi - I'm just starting to annotate my rebar on the sections, and I think I will be posting in here a lot.
To start with I'm using UK standards. I don't know if it is different elsewhere.
I want to tag 2 links in pairs.
I wouls like the text to look like:
     24H12-01-250
     24H12-02-250
     Links
Instead I get 2 separate Tags saying somethink like
     24H12 -02 -250mm
     Links
Is there any way of elevating a beam and combining the 2 tags?
How can I get rid of the spaces in the middle?
And the "mm" at the end of the Tag?
4 REPLIES 4
jachyme
in reply to: stewartg
Hi, it would be good if you attach a small sample file to see exactly what you are doing.
There are some enhancements in rebar tagging but I need to check if they are sufficient to your case.
Ewa Jachym
Principal User Experience Designer
stewartg
in reply to: jachyme
Hi Jachyme - Hope these screen dump's are good enough for you.
The Bar Marks 04, 05 and 06 are Annotation Text in the style I use in Autocad.
The Bar Marks 01, 02 and 03 are Rebar Tags.
03 is ok, although I would like to get rid of the spaces.
01 and 02 are links in pairs and I would like to combine them into a single tag. But I don't think that is possible. It's the "mm" at the end I would most like to get gid of.
I've also attached a copy of my Rebar Tag Family, I don't know if this will be of any use.
Stewart
jachyme
Hi, to get rid of "mm" just to go to Manage panel/Project Units find a sufficient unit and then set Unit symbol to "none"
Unfortunately you can't add a one Tag for 01 and 02. If you think it is important polease give us e few sample of different use cases.
Did you try MRA (Multi Rebar Annotation) for annotating rebar set ? Last position on Tag panel on Ribbon.
MRA works for rebar in rebar set and also for many single rebar but in view perpendicular to position of your 01 and 02. If these are stirrups in a beam you can use MRA for them but in the south view of this beam for instance.
Regards
Ewa Jachym
stewartg
Thanks Jackyme - I've got rid of the "mm" which was the main gripe
I did try MRA but could not get it to work.
I think it is important to group bars together in one callout eg "U Bars in Pairs" "Corner Bars" "Links in Pairs" or any position where there are multiple bars over exactly the same distance.
