Hi Again - This is getting to a question every day.
On the attached image the bar mark (02) is drawn to the correct dimensions and hosted in the ground beam, however it needs moving a few millimetres to the left.
If I try to move it, it will resize itself so that the right hand side does not move, although the left hand side does. The Right hand side is snapping to the cover line of the floor slab.
If I try to move it a bit further, then the left hand side snaps to the left hand floor slab.
Is there a way of stopping the link from snapping to the wrong member?
In this case both floor slabs span in the same direction, so I think I can combine them. But I have this detail all over the building, and not all slabs span the same way.
Solved by jachyme. Go to Solution.
Another fault related to my last post.
Attached is a screen capture from my bending schedule.
Note the link that I could not place on my last post (Bar mark 02). With a correct total length on Beams 1 and 2. But 25mm too short on beam 4. Even though all the dimensions are the same!
Hi, in case you have here it could be hard to get what you need manually. There is many constrains between rebar segments and hosts faces. If you use Constraints Manager it might be a litle bit easier. If you constrain rebar segments as "Constant offset" it will follow every host change.
