Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar Properties
4 REPLIES 4
492 Views, 4 Replies
Rebar Properties
Hello
I have a question and i hope to find an answer here
the letters 'a, b, c, c1,c2, d, d1, d2, e, e1, e2, f, f1, f2,...in the properties of rebar
my question is the schema of these parameters to understand which part can modified
please if someone can share a shema of these things.
4 REPLIES 4
jad.dellel
It depends on the type of the Rebar, but you could find the definition by following these easy steps:
1- Select your Rebar,
2- Edit Family
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
in reply to: jad.dellel
thank you for your answer but i want to see like this foto to understand
jad.dellel
I recorded all steps in this movie:
http://screencast.com/t/0QVUxzy6Bt
I hope this will be clear enough.
regards,
Jad DELLEL
Thank you very much for this video
Thank you very much again
