Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar partly not visible
2 REPLIES 2
ro78
625 Views, 2 Replies
I have views with from rebars (U-shaped) where the start/end of the turn is not visible.  I can't find the solution. See vertical bars below. (View depth is not the problem)
Revit Structure 2013 user
2 REPLIES 2
rileybreed
in reply to: ro78
5 years later, I'm having the same issue and can't seem to find a fix.
Revit 2018.3 having same issue.
Hello @rileybreed
Could you upload a sample model showing this issue?
It may be different than the original one.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
